16 visual effects are now available with rev 1.0:
- intro combining 3 classical effects : fire + dot donut + textual siner-scrollers.
- 3D Starfield v2.0
- XOR Moire v1.0
- Simple Blured & Bouncing Line v1.0
- Spline Distorsion v1.0
- Blured Bouncing Starspline v1.0
- Classical Amiga-Like Rotozoom v1.0
- Plasma Sinusoids v2.0
- Dot-Based Shapes Morphing v1.0
- Classical Lens Magnification v2.0
- Mesmerizing Rotating & Burning Cube v1.0
- Enter The Matrix v2.0
- Morphing & Blur v1.0
- Motion Blur on Spinning Cube v1.0
- Rotating Sphere on textured background v1.0
- Raindrops v2.0
I also added a control menu aiming at changing some options, we can briefly see it in action at the begining of the video.
Keys are :
The user can use the following keys to interract with the addin (we can also let it run without touching anything):
[EXIT] to leave back to the Operating System.
[F1] and [F6] to change manually the effect.
[OPTN] : to show/hide the option menu. While in this menu, the following keys can be used :
[UP / DOWN] : to select the parameter,
[LEFT / RIGHT] : to adjust the value of the parameter.
Hope you like it...
- 970.8 KB
- http://ceme.tech/DL2400
- slyVTT
- Repository where you can find the sources
- https://gitea.planet-casio.com/Slyvtt/ScreenSaver
- The topic following this contribution
- https://www.cemetech.net/forum/viewtopic.php?t=19332
- The CC26 CEMETECH Contest
- https://www.cemetech.net/forum/viewtopic.php?t=19320
- ↳ this version
- 68
- ↳ this version
- 516
- DemoFX for fx-CG50 v1.4 (unleashed extension of the CC 26 Contest) (published 11 months, 3 weeks ago; 2023-12-12 19:04 UTC)
- Cemetech CC26 contribution from SlyVTT : oldschool demo on fx-CG50 (published 1 year ago; 2023-11-22 08:14 UTC)
