Always-on Dark Mode
This program works similar to other dark mode programs for the TI-84 Plus CE,
with the exception that it will maintain dark mode even after turning the
calculator off and back on again.
To enable dark mode, all you need to do is run "prgmDARKINST" from the OS
programs menu. Keep in mind that shells (like Cesium) will interfere with this
program, as they use their own hooks which conflict with Always Dark. If for
whatever reason you reset your calculator, you'll need to run "prgmDARKINST"
again to re-enable dark mode. If your calculator is in dark mode and you'd like
to disable it, you can follow the same procedure by simply running
"prgmDARKINST" and your calculator will be back to normal again.
I'd like to give a massive thanks to RoccoLox Programs for being a huge help on
this project and writing a lot of the assembly code. Be sure to check out his
projects as well!
Screenshot #9084
always-dark-1.1/DarkHook.8xv 249 bytes
always-dark-1.1/DARKINST.8xp 360 bytes
always-dark-1.1/readme.txt 1.2 KB
1.5 KB
GitHub Repository
https://github.com/TIny-Hacker/always-dark
  1. Always-on Dark Mode (published 8 months, 3 weeks ago; 2024-05-03 21:31 UTC)
  2. Always-on Dark Mode (published 1 year, 5 months ago; 2023-08-22 14:57 UTC)
