RPN83P v1.1: RPN calculator for TI-83+ TI-84+ inspired by HP-42S
  3. TI-83 Plus/TI-84 Plus Assembly Programs
RPN83P is an RPN calculator app for the TI-83 Plus series and the TI-84 Plus series calculators. The app is inspired mostly by the HP-42S calculator, with some significant features borrowed from the HP-12C, the HP-16C, the HP-19BII, and the TI-85 calculators. RPN83P hopes to be the easiest and cheapest gateway app that introduces new users to the beauty and power of RPN calculators.
Features:
* traditional RPN stack (X, Y, Z, T, configurable from 4 to 8 levels), with LASTX register
* input edit line with scrollable cursor using arrow
* 8-line display showing 4 stack registers
* hierarchical menu system similar to HP-42S
* auto-start capability using the Start-Up app
* storage registers (resizable 25-100) and variables (A-Z,Theta)
* all math functions with dedicated buttons on the TI-83 Plus and TI-84 Plus
* STAT statistics and CFIT curve fitting, inspired by HP-42S
* BASE conversion and bitwise operations, inspired by HP-16C and HP-42S
* TVM time value of money, inspired by HP-12C, HP-17B, and HP-30b
* CPLX complex numbers, inspired by HP-42S and HP-35s
* UNIT conversions of ~170 units, inspired by HP-19BII and TI-85
* DATE: date, time, datetime, timezone, hardware clock, proleptic Gregorian calendar from 0001 to 9999
Installation:
* Install the rpn83p.8xk flash app file.
Starting:
* Press APPS.
* Scroll down to the RPN83P entry.
* Press ENTER.
Exiting:
* Quit app: 2ND QUIT
* Turn off device: 2ND OFF
Version: 1.1.0 (2025-10-07)
Major Changes from 1.0.0:
* WARNING: upgrading from v1.0 to v1.1 will cause MODE settings to be reset to factory values; but preserves RPN stack (X-T,A-D), storage registers (R00-R99), storage variables (A-Z,Theta), STAT registers (SigmaX-SigmaYLX), TVM registers
* reorganize BASE menu, no functional change
* reorganize DATE menu, new entry methods
* reimplement UNIT conversions, now similar to TI-85 and HP-19BII, expand supported units from 30 to ~170
* fix RPN stack and LASTX edge cases
* reorganize USER_GUIDE into 21 chapters, merged into a single PDF for release
* now consumes 4 flash pages (64 kiB), increase from 3 flash pages
Screenshot #10363 Screenshot #10364 Screenshot #10365 Screenshot #10366
CHANGELOG.md 38.9 KB
README.pdf 203.7 KB
USER_GUIDE.pdf 1.5 MB
rpn83p-example1.gif 26.1 KB
rpn83p-example2.gif 85.0 KB
rpn83p-example3.gif 86.0 KB
rpn83p-example4.gif 156.8 KB
rpn83p.8xk 139.6 KB
1.7 MB
bxparks
GitHub
https://github.com/bxparks/rpn83p
Cemetech Forum
https://www.cemetech.net/forum/viewtopic.php?t=19209
Museum of HP Calculators
https://www.hpmuseum.org/forum/thread-24151-post-210699.html
10/10 (2 votes)
Combine this assembly program with the custom start-up application from Ti and you have yourself a full-function RPN calculator on the Ti-83/84 Plus platform. Software-wise, everything you'd expect from an RPN calculator is there and easy to access through the menu system and already existing keys on the caculator.
  1. RPN83P v1.1.1: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 6 months ago; 2025-11-14 17:23 UTC)
  2. RPN83P v1.1: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 7 months, 1 week ago; 2025-10-11 16:35 UTC)
  3. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 1 year, 9 months ago; 2024-07-22 17:33 UTC)
  4. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 1 year, 10 months ago; 2024-06-27 19:47 UTC)
  5. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 1 year, 11 months ago; 2024-05-31 17:00 UTC)
  6. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 1 month ago; 2024-04-02 17:25 UTC)
  7. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 4 months ago; 2024-01-08 00:39 UTC)
  8. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 5 months ago; 2023-12-04 01:31 UTC)
  9. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 5 months ago; 2023-11-20 20:22 UTC)
  10. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 7 months ago; 2023-09-23 00:26 UTC)
  11. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 8 months ago; 2023-09-01 03:53 UTC)
  12. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 9 months ago; 2023-08-17 01:36 UTC)
  13. RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 9 months ago; 2023-08-14 16:19 UTC)
