RPN83P is an RPN calculator app for the TI-83 Plus and the TI-84 Plus. The app is inspired mostly by the HP-42S calculator, with significant features from the HP-12C and the HP-16C. RPN83P is a flash application that consumes 3 pages (48 kiB) of flash memory.
Features:
* traditional RPN stack (X, Y, Z, T) with LastX register (resizable, 4 to 8 levels)
* scrollable input cursor
* 8-line display showing 4 stack registers
* storage registers (resizable, 25 to 100 registers)
* storage variables (27, A to Z, and Theta)
* hierarchical menu system
* support for all dedicated math buttons on the TI-83 Plus and TI-84 Plus
* additional advanced math menu functions (MATH)
* arithmetic functions, prime factorization (NUM)
* angle conversions (CONV)
* hyperbolic functions (HYP)
* probability functions (PROB)
* unit conversions (UNIT)
* base conversions and bitwise operations (BASE)
* 1 or 2 variable statistics (STAT)
* curve fitting, linear, logarithmic, exponential, power (CFIT)
* time value of money (TVM)
* complex numbers (CPLX)
* date, time, datetime, timezone, and real-time clock (DATE)
* various display modes (FIX, SCI, ENG)
Installation:
* Install the rpn83p.8xk flash app file.
Starting:
* Press APPS.
* Scroll down to the RPN83P entry.
* Press ENTER.
Exiting:
* Quit app: 2ND QUIT
* Turn off device: 2ND OFF
Version: 1.0.0 (2024-07-19)
Major Changes from 0.12.0:
* graduate from Beta to v1.0
* increase accuracy of TVM when I%YR is very close to 0%
* improve speed of Prime Factor function PRIM by 2.4X
* add additional UNIT conversions
* CLEAR erases only to end of line if cursor is inside the input line
| Name | Size |
| CHANGELOG.md | 32.6 KB |
| FUTURE.pdf | 48.3 KB |
| README.pdf | 74.2 KB |
| TVM.pdf | 71.8 KB |
| USER_GUIDE.pdf | 650.6 KB |
| USER_GUIDE_BASE.pdf | 84.0 KB |
| USER_GUIDE_COMPLEX.pdf | 127.5 KB |
| USER_GUIDE_DATE.pdf | 448.7 KB |
| USER_GUIDE_STAT.pdf | 68.6 KB |
| USER_GUIDE_TVM.pdf | 68.2 KB |
| rpn83p-example1.gif | 26.1 KB |
| rpn83p-example2.gif | 78.2 KB |
| rpn83p-example3.gif | 86.0 KB |
| rpn83p-example4.gif | 156.8 KB |
| rpn83p.8xk | 107.7 KB |
- 1.6 MB
- http://ceme.tech/DL2376
- bxparks
- Cemetech Forum
- https://www.cemetech.net/forum/viewtopic.php?t=19209
- Museum of HP Calculators
- https://www.hpmuseum.org/forum/thread-20867.html
- 10/10 (2 votes)
- ↳ this version
- 435
- ↳ this version
- 1559
Combine this assembly program with the custom start-up application from Ti and you have yourself a full-function RPN calculator on the Ti-83/84 Plus platform. Software-wise, everything you'd expect from an RPN calculator is there and easy to access through the menu system and already existing keys on the caculator.
- RPN83P v1.1.1: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 months, 4 weeks ago; 2025-11-14 17:23 UTC)
- RPN83P v1.1: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 4 months ago; 2025-10-11 16:35 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 1 year, 6 months ago; 2024-07-22 17:33 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 1 year, 7 months ago; 2024-06-27 19:47 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 1 year, 8 months ago; 2024-05-31 17:00 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 1 year, 10 months ago; 2024-04-02 17:25 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 1 month ago; 2024-01-08 00:39 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 2 months ago; 2023-12-04 01:31 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 2 months ago; 2023-11-20 20:22 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 4 months ago; 2023-09-23 00:26 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 5 months ago; 2023-09-01 03:53 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 5 months ago; 2023-08-17 01:36 UTC)
- RPN83P: RPN calculator for TI-83+ TI-84+ inspired by HP-42S (published 2 years, 5 months ago; 2023-08-14 16:19 UTC)
