- TI-84 Plus C Silver Edition BASIC Games
First Fantasy is one of the first RPG ever released for the TI-84 Plus C Silver Edition and the first ever one for the TI-84 Plus CE, TI-83 Premium CE and (if you have OS 5.6.4 or older) TI-82 Advanced Edition Python! The CSE version uses Doors CSE 8.1 libraries to enhance TI-BASIC language, while the CE/82AEP version uses CE Textlib or Celtic CE (two versions of the CE game are available but the Celtic one is recommended) and a custom font. This very loose remake of Mana Force for the 83+ brings enhanced graphics, new magic spells and enemies, new cutscenes, expanded storyline and many new challenges. There are 16 magic spells available, 7 character classes, 8 dungeons (13 in the CE version), 49 monsters (79 in the CE version) and several hours of gameplay. If you are a fan of Square-Enix Japanese role-playing games such as Final Fantasy, then you should try it! This update ports some of the previous Celtic CE version updates to the CE Textlib version.
If you have a TI-82 Advanced Edition Python then you need OS 5.6.4 or lower in order to play, as ASMHOOK is no longer working on 5.6.5. BE CAREFUL! If you use OS 5.8.3 on your TI-83 Premium CE or TI-84 Plus CE to run the game, then NEVER press the ON key while the game is running, otherwise the calculator will crash and reboot, followed by a RAM Clear. Use the CLEAR key outside of battles instead. I also recommend not upgrading to OS 5.8.3.
| Name | Size |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/FFMANA.8xp | 821 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Ignore_Me.txt | 19.8 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/mapsWalkthrough.txt | 60 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/MF.8xp | 2.2 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/MF1.8xp | 21.5 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/MFB.8xp | 12.4 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/MFF.8xp | 12.3 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/MFH.8xp | 1.3 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 2.0 (with text)/FFMANA.8xp | 187 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 2.0 (with text)/Ignore_Me.txt | 10.0 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 2.0 (with text)/MF.8xp | 2.1 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 2.0 (with text)/MF1.8xp | 14.4 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 2.0 (with text)/MFB.8xp | 9.9 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 2.0 (with text)/MFH.8xp | 885 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 2.0 (with text)/ZSCRINV.8xp | 97 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 3.1 (with sprites)/FFMANA.8xp | 486 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 3.1 (with sprites)/Ignore_Me.txt | 11.1 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 3.1 (with sprites)/MF.8xp | 2.1 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 3.1 (with sprites)/MF1.8xp | 14.6 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 3.1 (with sprites)/MFB.8xp | 10.4 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 3.1 (with sprites)/MFF.8xp | 6.7 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 3.1 (with sprites)/MFH.8xp | 885 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/Old/Version 3.1 (with sprites)/ZSCRINV.8xp | 97 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/ZFASTKEY.8xp | 91 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/CE Textlib version/ZSCRINV.8xp | 97 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/Celtic CE version/FFMANA.8xp | 899 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/Celtic CE version/Ignore_Me.txt | 21.0 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/Celtic CE version/mapsWalkthrough.txt | 60 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/Celtic CE version/MF.8xp | 1.7 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/Celtic CE version/MF1.8xp | 20.2 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/Celtic CE version/MFB.8xp | 11.4 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/Celtic CE version/MFF.8xp | 12.3 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/Celtic CE version/MFH.8xp | 847 bytes |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/mapsWalkthrough.zip | 11.7 KB |
| TI-84 Plus CE, TI-83 PCE & TI-82 AEP/mapWalkthrough.txt | 60 bytes |
| TI-84 Plus C Silver Edition/FFMANA.8xp | 470 bytes |
| TI-84 Plus C Silver Edition/Ignore_Me.txt | 9.8 KB |
| TI-84 Plus C Silver Edition/MF.8xp | 2.1 KB |
| TI-84 Plus C Silver Edition/MF1.8xp | 6.0 KB |
| TI-84 Plus C Silver Edition/MF2.8xp | 5.8 KB |
| TI-84 Plus C Silver Edition/MF3.8xp | 3.8 KB |
| TI-84 Plus C Silver Edition/MFB.8xp | 7.8 KB |
| TI-84 Plus C Silver Edition/MFM.8xp | 2.8 KB |
- 125.7 KB
- http://ceme.tech/DL1277
- DJ Omnimaga
- ArTIfiCE
- https://yvantt.github.io/arTIfiCE/
- Cemetech topic
- https://www.cemetech.net/forum/viewtopic.php?t=11395
- 8.3/10 (12 votes)
- ↳ this version
- 596
- ↳ this version
- 2190
This game uses Asm() tokens, which where removed in OS 5.5. This means that the game will not run at all on those versions.
The reason is because the game is a TI-BASIC program, while all the files are in ASM.
Guess this game is just a waste of space on my calculator until they make the game runnable on ASM.
0/10
So my shell is the "CalcPlex" shell. But how do I "hide" the rest of the other programs? Like the game is there, but there is also MF, MF1, MFB, MFF, and MFH. Is there a way to make them still on my calculator but not seeable?
It doesn't work. I installed all the necessary program files and have Artifice installed on my calculator, but it still throws an ERROR: INVALID when I try to run the main program. Well, didn't expect a full RPG on a freaking calculator, anyway. It's a pity since the descriptions in the readme file made this seem absolutely epic.
This program was developed by a master. The program isn't too slow and isn't a big memory hogger. The only thing I wish it did by default was archive the saves. The game crashed once and I lost my save, so I modded the program to archive them AND create a save data backup every time you save.
I suggest anyone who downloads this to mod the program to back up or archive save data. CE Textlib doesn't crash often, but you never know when it does.
One of my favorite things about this game is the suspense. You don't know how often enemies will appear, and it's really fun. A well made TI-Basic game.
This is a very good program. It has some decent graphics and is not to laggy.
- First Fantasy: Mana Force v6.0.5 (published 7 months, 3 weeks ago; 2025-09-24 23:49 UTC)
- First Fantasy: Mana Force v6.0.5 (published 8 months, 2 weeks ago; 2025-08-29 22:00 UTC)
- First Fantasy: Mana Force v6.0.5 (published 9 months, 2 weeks ago; 2025-07-30 03:53 UTC)
- First Fantasy: Mana Force v6.0.4 (published 10 months, 1 week ago; 2025-07-06 04:41 UTC)
- First Fantasy: Mana Force v6.0.3 (published 1 year ago; 2025-05-05 23:01 UTC)
- First Fantasy: Mana Force v6.0.2 (published 1 year, 1 month ago; 2025-03-17 18:17 UTC)
- First Fantasy: Mana Force v6.0.1 (published 1 year, 2 months ago; 2025-03-04 03:55 UTC)
- First Fantasy: Mana Force v6.0.1 (published 1 year, 2 months ago; 2025-02-28 03:18 UTC)
- First Fantasy: Mana Force v6.0.0 (published 1 year, 2 months ago; 2025-02-24 23:35 UTC)
- First Fantasy: Mana Force v5.4.0 (published 1 year, 2 months ago; 2025-02-20 21:59 UTC)
- First Fantasy: Mana Force v5.3.1 (published 1 year, 3 months ago; 2025-02-14 04:11 UTC)
- First Fantasy: Mana Force v5.3.0 (published 1 year, 3 months ago; 2025-02-03 04:16 UTC)
- First Fantasy: Mana Force v5.2.0 (published 1 year, 4 months ago; 2025-01-09 20:38 UTC)
- First Fantasy: Mana Force v5.2.0 (published 1 year, 6 months ago; 2024-11-15 21:27 UTC)
- First Fantasy: Mana Force v5.1.0 (published 1 year, 6 months ago; 2024-11-09 22:52 UTC)
- First Fantasy: Mana Force v5.0.0 (published 1 year, 6 months ago; 2024-11-08 03:22 UTC)
- First Fantasy: Mana Force v4.6.0 (published 1 year, 7 months ago; 2024-09-30 15:56 UTC)
- First Fantasy: Mana Force v4.5.3 (published 1 year, 7 months ago; 2024-09-23 16:57 UTC)
- First Fantasy: Mana Force v4.5.3 (published 2 years, 3 months ago; 2024-02-02 21:19 UTC)
- First Fantasy: Mana Force v4.5.3 (published 2 years, 5 months ago; 2023-12-12 19:08 UTC)
- First Fantasy: Mana Force v4.5.3 (published 2 years, 5 months ago; 2023-12-06 20:37 UTC)
- First Fantasy: Mana Force v4.5.3 (published 2 years, 5 months ago; 2023-11-18 04:22 UTC)
- First Fantasy: Mana Force v4.5.3 (published 4 years, 8 months ago; 2021-09-13 11:05 UTC)
- First Fantasy: Mana Force v4.5.2 (published 5 years, 1 month ago; 2021-04-10 21:22 UTC)
- First Fantasy: Mana Force v4.5.1 (published 5 years, 1 month ago; 2021-04-04 11:38 UTC)
- First Fantasy: Mana Force v4.5 (published 5 years, 1 month ago; 2021-04-03 22:55 UTC)
- First Fantasy: Mana Force v4.3.2 (published 5 years, 1 month ago; 2021-03-24 17:31 UTC)
- First Fantasy: Mana Force v4.3.1 (published 5 years, 1 month ago; 2021-03-24 15:49 UTC)
- First Fantasy: Mana Force v4.2.1 (published 5 years, 1 month ago; 2021-03-23 15:51 UTC)
- First Fantasy: Mana Force (published 5 years, 1 month ago; 2021-03-21 20:08 UTC)
- First Fantasy: Mana Force (published 5 years, 2 months ago; 2021-03-15 15:52 UTC)
- First Fantasy: Mana Force (published 5 years, 2 months ago; 2021-03-11 21:50 UTC)
- First Fantasy: Mana Force (published 5 years, 2 months ago; 2021-03-01 19:33 UTC)
- First Fantasy: Mana Force (published 5 years, 6 months ago; 2020-10-29 20:57 UTC)
- First Fantasy: Mana Force (published 5 years, 11 months ago; 2020-06-12 21:26 UTC)
- First Fantasy: Mana Force (published 5 years, 11 months ago; 2020-06-01 16:43 UTC)
- First Fantasy: Mana Force (published 5 years, 11 months ago; 2020-06-01 00:41 UTC)
- First Fantasy: Mana Force (published 10 years, 8 months ago; 2015-09-07 20:07 UTC)
